Ethan Posted April 24, 2005 Share Posted April 24, 2005 I like to export User Fields 1 and 2 every time I send info out to Lightwright. I find that saving an export map file and having to access it every time I export is actually slower than clicking "Lightwright" and then manually adding in the User Fields from the list. I notice there is a button called "User...", which is defined in the help file as "Restores the last saved or loaded set of instrument data fields." Sounds like exactly what I need. However, this button is always grayed and inactive. What does it take to activate it? Ethan Mac OS 10.3.9 Vectorworks Spotlight 11.5 Quote Link to comment
Mickey Posted April 25, 2005 Share Posted April 25, 2005 You've lost me. Is that user button in LW or VW? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted April 25, 2005 Vectorworks, Inc Employee Share Posted April 25, 2005 The User button will enable once you load a saved set. It will restore the last set of values that you loaded during this session. It works, but it seems kind of usless when you think about it. I'll add it to the bug list because I think it was intended to do something different. Quote Link to comment
