cartier Posted September 20, 2006 Share Posted September 20, 2006 Since I updated to VW 12.5. (Mac PowerBook OSX 1.5GHz, 1GB ram) It is nearly impossible to export DWG (long 10min+ export times. On VW 11 iu used to take less than 1min). Is this normal?? Quote Link to comment
0 Guest Posted September 20, 2006 Share Posted September 20, 2006 It depends on the options you have selected in the export dialog box. VW 12 offers a wider variety of export functions, with the need to write more information and export the vector-based information with more details. If you can give a little more information about the types of settings you have on, versions, vw file size, etc. we could better assist you. Quote Link to comment
0 cartier Posted September 20, 2006 Author Share Posted September 20, 2006 I tried exporting Sheets with 1 or 2 viewports, anotations, crops and a Drawingborder with Title. DWG sise around 1mb (Second Problem: the dimensions also are ofset by half the drawing dimension this also happend in VW 11) Exporting the design layer by itself generates a DWG of about 1mb, the vw file is roughly 20mb. I hope the problem of fast exporting and correct position of the dimensions can be solved! Until then its back to working like in good old VW 10. thanks in advance Alexander Quote Link to comment
0 borgo1971 Posted September 20, 2006 Share Posted September 20, 2006 I've experienced the same issue after upgrading from VW12 to 12.5. I've a 40Mb file (only 2D objects), that was exported in about 1 min. with VW12, now it takes about 10 minutes, 9 of them standing at 1/10 of progress bar. Although exported DWG seems to be OK (circa 30Mb with 6 Sheets and 2 viewport for each). In my opinion there's something wrong in DWG export from VW12.5, and there aren't any new futures over VW 12.0.1 that can justify this slowness. Hope there will be soon a patch. Quote Link to comment
0 Guest Posted September 20, 2006 Share Posted September 20, 2006 Please send files demonstrating this behavior to bugsubmit@nemetschek.net and tech@nemetschek.net Quote Link to comment
0 borgo1971 Posted September 22, 2006 Share Posted September 22, 2006 I've sendet the file to bugsubmit@nemetschek.net but I've got a failure notice (the compressed file is about 10 Mb). Any other idea? Quote Link to comment
0 Guest Posted September 22, 2006 Share Posted September 22, 2006 Make sure the email was sent to nemetschek.NET and not .com You should also send the file to tech@nemetschek.nat, per my previous suggestion. Quote Link to comment
0 gScott Posted September 24, 2006 Share Posted September 24, 2006 Make sure the email was sent to nemetschek.NET and not .com You should also send the file to tech@nemetschek.nat, per my previous suggestion. not sure that the ".nat" is going to get you there? Quote Link to comment
0 borgo1971 Posted September 25, 2006 Share Posted September 25, 2006 I'll try again. Quote Link to comment
cartier
Is this normal??
8 answers to this question
