milon Posted September 19, 2006 Share Posted September 19, 2006 Can anybody tell me, how can i change the unit (show area) in the "space" vectorscript from -> "S.M." to -> "m2" unfortunately the script is locked thanks forward Quote Link to comment
PeterT Posted September 19, 2006 Share Posted September 19, 2006 The unit mark is controlled by the Units dialog in File/Document Settings, not by the plug-in. If you want a square unit mark different than the VectorWorks default, you can go to the Units dialog, create a custom square unit for meters and give it any custom unit mark you want. If you then set your document to use this custom square unit, when the plug-in is used, it will display with the unit mark of your choice. Quote Link to comment
Itchy Posted September 20, 2006 Share Posted September 20, 2006 rather than m2 wouldnt it be better being m?? to get the ? hold down alt and type 0 1 7 8 on the keypad Quote Link to comment
milon Posted September 21, 2006 Author Share Posted September 21, 2006 thanks for your reply but If I made a custom units in Document settings they change only on "object info" and not on the draw (Space vectorscript) do I somthing wrong? cheers Quote Link to comment
gScott Posted October 1, 2006 Share Posted October 1, 2006 on my version 12.5 win, the space area units "S.M." cannot be changed by fiddling with custom units. this has been discussed before + there is some hack to mac systems that can be done, but not windows.... bill gates would call it a "feature" Quote Link to comment
