how change unit in the "space" vs
milon
The unit mark is controlled by the Units dialog in File/Document Settings, not by the plug-in. If you want a square unit mark different than the VectorWorks default, you can go to the Units dialog, create a custom square unit for meters and give it any custom unit mark you want.
If you then set your document to use this custom square unit, when the plug-in is used, it will display with the unit mark of your choice.
  • 2 weeks later...
