msclark Posted September 13, 2006 Share Posted September 13, 2006 The window schedule does not display the windows in order based on their ID #. I played with the display order by sending some windows and walls to the back, front, etc. and it changes the display order in the window schedule!? Why don't they display in order (W-01, W-02....) by Id # - is there a way to change this in the window schedule? Matt Quote Link to comment
bclydeb Posted September 15, 2006 Share Posted September 15, 2006 MSClark, The secret is in the sorting icons which appear at the top of the spreadsheet window when you select the database row. The sorts are ascending, descending and the third subtotals (counts) all the same entries. Drag the ascending icon into the column you wnat to sort by in the database row and it will order the windows (doors) according to your system. It is good that you know the other secret to proper ordering - to put a zero before the ordinal number so that the schedule will sort properly. e.g your example W-01, W-02 ... W-09, W-10 will sort properly. W-1, W-2, etc. will order as W-1, W-10,W-2, W-20 etc. I hope this helps. Quote Link to comment
msclark Posted September 15, 2006 Author Share Posted September 15, 2006 thanks, thats what I was looking for! Quote Link to comment
OneWorld Posted October 4, 2006 Share Posted October 4, 2006 Wow, thanks for that. This was making me nuts. That was not the most obvious thing to do... Quote Link to comment
