aleverda Posted September 13, 2006 Share Posted September 13, 2006 I own the student version of V12 and am puzzled by my lights, lighting positions and set pieces literally not being visible (but still selectable) while Class- Active Only is selected. However they are visible when Classes-Show/Snap Others and Show/ Snap Modify Others is selected. As I need to have a lighting bar created out of the same symbol and placed directly beneath the other one this is particularly frustrating! Is the only option to set one bar?s class visibility as invisible whilst editing the other? Another quirk is that a symbol can be inserted repeatedly into the same class as a lighting position while Classes- Active Only is selected and still be visible and the height editable while if it?s inserted into a different class from the other symbol it will not be visible and the height will not alter from zero unless viewed in Class- Show/Snap Others and is altered from there. Any suggestions? Quote Link to comment
Jim_Allen Posted September 13, 2006 Share Posted September 13, 2006 Have you considered using different layers? Jim Quote Link to comment
Nik Posted September 13, 2006 Share Posted September 13, 2006 The objects within your symbols, ie the actual lines etc. are probably not in the same class that you had active when you converted them lighting positions. When you choose "active class only" the class of the lines etc. within the symbol are not in the currently active class and poof they disappear. But since the Lighting Position Object IS in the active class it appears invisible but you can still select it. Quote Link to comment
aleverda Posted September 15, 2006 Author Share Posted September 15, 2006 (edited) Thanks Nik, It's frustrating but your answer is correct. Does this mean that while constructing a symbol you should always be careful to create it in the class that you will eventually use it in? Edited September 15, 2006 by aleverda Quote Link to comment
Thea Posted September 16, 2006 Share Posted September 16, 2006 I think making a specific class that you create symbols in and always leave on would work. Or maybe one class for instrument symbols, another for hanging positions etc. Quote Link to comment
