MacDaid
Print error: "pictwpstops" stopped unexpectedly
Can anyone shed some light on the following error?
In the print monitor (print cue Mac OSX 10.4.7) the message
"The process "pictwpstops" stopped unexpectedly with status 1" appears very briefly, and the file fails to print.
Other spec.
Printer: HP 1055
VW 11.5.1
Repair permissions failed to fix it,
Re-add of printer driver failed to fix it
Any tips? Suggestions?
Thanks in advance....
1 answer to this question
Check out either HP's website or contact HP directly to diagnose the error message. If it appears on the control panel of the printer, there is likely something out of sync with the printer or printer driver/os combo
Likewise, there's a repair printers option under one of the menus in the print center utility. You may want to try to run that, too.
