sfatelier Posted September 12, 2006 Share Posted September 12, 2006 I don't know why some walls appear solid and others as wireframes when I render a perspective in open GL. Can anyone explain to me why this occurs. I have used the walltypes from the program (v. 12 - pc). Thank you! Quote Link to comment
propstuff Posted September 12, 2006 Share Posted September 12, 2006 Are the wireframe walls set to have a solid fill? Quote Link to comment
P Retondo Posted September 12, 2006 Share Posted September 12, 2006 Select a wall, look at the attributes palette. It must have a solid fill (first part of that palette), otherwise your textures won't appear. Quote Link to comment
sfatelier Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks! I'll try that. I kept focusing on the object info palette. Quote Link to comment
sfatelier Posted September 12, 2006 Author Share Posted September 12, 2006 I tried that but when I select the wall, the attributes becomes grey and I can't change the fill or line settings. What's with that? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted September 12, 2006 Vectorworks, Inc Employee Share Posted September 12, 2006 sfatelier, styled walls are controlled by their style definitions, not by the attributes palette (kind of like symbols). If you want to control a wall using the attribute palette, unstyle the wall first by choosing "convert to un-styled wall" in the Object Info palette. Quote Link to comment
sfatelier Posted September 12, 2006 Author Share Posted September 12, 2006 OK I'll try that. It's odd that this wall (8" CIP concrete) is one of the Vectorworks standards and it's not set up to render as solid. Thanks Quote Link to comment
sfatelier Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks, that did it! Any explanation on the fact that some walls behave that way and others don't? Quote Link to comment
