Hello, I was hoping someone could give me an idea as to the best way to create proper PDF's for use by my local printer. My drawing sheet size is Arch D (24x36) but my own printer will only print 13 x 19 maximum.
I can export all of the sheets as image files and compile them into a PDF. When I open the PDF my size indicated in the lower left hand corner of the PDF window says 13 x 19.
This has me thinking it will print to that size as compared to my sheet size of 24 x 36. Am I correct? Will I have to install some large format printer driver in order to spec 24 x 36 in Page Set-up and then be able to actually export JPEGS at 24 x 36?
What might be my best strategy to generate a file of my sheets that I know are the right size? Thanks, Bradley
bc
Perhaps this is the best place for my querie.
3 answers to this question
