eric.rktek Posted September 1, 2006 Share Posted September 1, 2006 Is there a way to assign a class to a wall component? If not, I think this would be a really useful feature to add. I would really like to be able to assign class attributes to the lines and would also like the ability to turn the components on and off in viewports (so the could components could be turned off for smaller scale plans). Quote Link to comment
carpalmer Posted September 2, 2006 Share Posted September 2, 2006 YES! and then you could turn off finish components for wall in Structural plans! Otherwise I always end up using "non-component" also I can draw wall ONCE, and correct if necessary ONCE... problem is that I have to live with an inaccurate thicknesses (have to choose to be too thin in architectural plans, or too thick in structural...) Quote Link to comment
panthony Posted September 2, 2006 Share Posted September 2, 2006 Have you tried using the "Hide wall components" selection in the documents prefrences? It might help to hide small wall component detail at reduced scale drawings. Quote Link to comment
