john vs Posted August 25, 2006 Share Posted August 25, 2006 I have an extruded rectangle and an object I created with the sweep tool and a locus. They intersect. When I try Add Solids, I get a message that says "You are trying to create a 3D solid from a sweep containing a Locus within the horizontal span of its defining polygon. Move the locus beyond the left or right edge of defining geometry to resolve this error." First, why is this an error? Second, I edit the sweep object and delete the locus and, well, you know what I am going to say next. Deleting the locus is not the answer. What do I do to add these two solids? Thanks. Quote Link to comment
Kaare Baekgaard Posted August 25, 2006 Share Posted August 25, 2006 The locus needs to be exactly aligned to- or further out than the leftmost- or rightmost part of the profile object. No particular reason to this, I guess - that's just the way it is. Try using the align menu item. Quote Link to comment
john vs Posted August 25, 2006 Author Share Posted August 25, 2006 Thanks, Kaare. The locus is used to define the shape of the swept 3D object. How can I move it and not change the shape of the object? Why is the location of the locus even an issue? Where is this explained in the manual? Quote Link to comment
alanmac Posted August 25, 2006 Share Posted August 25, 2006 Hi John Does it work if you use extrude along a path to create one of the objects instead of sweep creation, or is it required to use sweep? What are your VW version and OS/machine details by the way. Alan Quote Link to comment
john vs Posted August 25, 2006 Author Share Posted August 25, 2006 I got something that works. Originally, I was using an arc and a locus to create a foorball shape. I guess this does not create a solid, so I created a closed shape by adding a line (the rotation point) and connecting the arc to it, then deleted the locus and swept about the line. I took that shape and did the Add Solids and it worked. This documentation leaves a lot to be desired! Quote Link to comment
