Assembly Posted August 22, 2006 Share Posted August 22, 2006 All our Macs are networked through a gigabit switch. Our i9950 is Firewire connected to an imacG4 running osx10.3.9 Print Sharing is turned on. We can print over the network from all software, except Vectorworks. When a print is sent from VW the printer just stops. The printer utility says 'Job Stopped.' The same drawing can be printed to PDF, the PDF sent to the printer over the network and it prints. Anyone have similar problems or know how to fix Quote Link to comment
0 Guest Posted August 23, 2006 Share Posted August 23, 2006 (edited) Try printing a new, blank document w/ just a line or something simple placed in the drawing. See if the printer utility or printer display gives you any additional information other than "job stopped". Usually, either the monitor or the display give you something more than "job stopped" when something like this happens. Are you using a built in, manufacturer, or 3rd party print driver? Is everyone else in the office having the same problem? Edited August 23, 2006 by Katie Quote Link to comment
Assembly
1 answer to this question
