Jake Posted August 17, 2006 Share Posted August 17, 2006 This has occured on several of our files; as far as I can tell, at some point, all objects in the file (callouts, detail tags, section tags, etc.) turned into un-editable 'plug-in objects.' The OIP shows them with no editable attributes, dimensions, etc. Unfortunately, there have been multiple people working on the set, so I can't determine a clear history in terms of what has been done to the files. Is there any kind of fix for this, or will we need to either explode all our annotation symbols/make new ones? I'm reluctant to use callouts, etc. after this, on the chance that we'll end up with another set with uneditable notes right before a deadline. Quote Link to comment
Cris with no H Posted August 18, 2006 Share Posted August 18, 2006 Check serial numbers. Objects created in Design will show up, but not be editable, in basic Vectorworks. Quote Link to comment
Guest Posted August 19, 2006 Share Posted August 19, 2006 Jake, The other thing to check is the object type you have selected. Select the callout. At the top of the Object Info Palette, you should see the object type listed. What is the object type? As Cris suggests, make sure you are not using a Fundamentals copy of VW, too. Quote Link to comment
Kong Posted August 20, 2006 Share Posted August 20, 2006 Plug-in Object of VW Architect, VW Landmark, ... un-editable in VW foundation.. but Callouts case, i don't know cause if you must edit it (not more). may use the ungroup command with Plug-in Objects to plain objects. Quote Link to comment
Jake Posted August 21, 2006 Author Share Posted August 21, 2006 Katie: In the OIP, the callout is simply called a 'plug-in object' and has blank x,y,z, and rotation fields. It shows a class and layer pulldown tab; class is editable, layer is not, as it's within a viewport annotation space. We use basic Vectorworks, but the file has not left the office, and all of our seats have the base Vectorworks licensed. Quote Link to comment
Guest Posted August 22, 2006 Share Posted August 22, 2006 Jake, Send the file to tech@nemetschek.net and one of us can take a look at it. Quote Link to comment
