wall line weight editing
SF, you don't say what version you are using.
You can't change the wall lines using the attributes palette probably because the components still have lineweights defined - I believe the component line weights override the wall lineweight.
The following may have particulars unique to version 12, and may assume you are using VW Architect: The other method is to use wall styles. Create your style, apply it to the wall, and then edit it later to effect global changes. One caution: files converted from earlier versions of VW have extremely time-consuming bugs associated with editing wall styles.
Dear BC, I have version 12, Architect, on a pc. Sorry for the confusion. I did manage to change them by changing the wallstyle to "unstyled". Previously with an assigned style, the component option wasn't available. With the change to "unstyled", I was able to change it as you directed. Thanks all for your help!
