Dexie Posted August 17, 2006 Share Posted August 17, 2006 I have been sent survey data in the form of a text file but cannot import it into a VW blank drawing sheet the data looks like - 472340,262560,84 472340,262570,84 472340,262580,84 472340,262590,84 472340,262600,84 472340,262610,84 472340,262620,84 472340,262630,86 472340,262640,86 472340,262650,86 472340,262660,86 472340,262670,86 472340,262680,86 472340,262690,86 Can anyone advise me on how to to do this. I have followed the import survey data instuctions and used coma separated text option but nothing happens. Thank you in advance. Quote Link to comment
dspearman Posted August 17, 2006 Share Posted August 17, 2006 My thought is that you are creating stake object but that the objects created are a long way from the drawing origin. After the import, but before clicking on the drawing look at the object info pallet. You should see that a number of stake objects are selected. This is the imported data. If you want to see them run the command View > Zoom > Fit to objects. Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 No nothing appears in the drawing. If I select AEC > Survey Input > Import survey file,... bowse to the text document. Data from selected file.< Line 1 > should enable me scroll through the data I think. But no data appears. I have chosen the Field separator as , (coma) but nothing happens. I am confused. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 17, 2006 Vectorworks, Inc Employee Share Posted August 17, 2006 What version and platform are you using? I tried it with the 14 data points you listed on 12.0.1 in windows and it worked fine. Quote Link to comment
Christiaan Posted August 17, 2006 Share Posted August 17, 2006 Can you post the entire file Dexie? Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 The first two numbers on each line are grid coordinates and the third is the height value which can vary. Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 I'm using a G5 Powermac VW 12.0.1. I've tried again with the 14 lines of data and it comes up with "bad data line 2" . This time data does appear in the <Line> data box but data in addition to the coordinates appers. eg. {\rtfl\mac in Line 1 {\fontfbl\f0\fswiss in Line 2 not until line 8 does the coordinate data kick in. This text does not appear in the text document imported it appears to be invisible coding or something. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 17, 2006 Vectorworks, Inc Employee Share Posted August 17, 2006 It sounds like there is some extra data in the text file. The comand will read all the data between the last coma and the <eoln> character and use it as the third data point. If it contains something other then a vaild number, the command will produce the error. Try opening the file in a text editor that will chao wal the hidden characters and see what extra data is there, or copy and paste all the data into a simple text file and see if that clears things up. Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 I've trid the same text file on one of our PC and it seems to be working. The Mac is picking up something fro the TextEdit document that it shouldn't. Simple text doesn't seem to be available. Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 The whole file a little large at 3.2Mb Quote Link to comment
Dexie Posted August 17, 2006 Author Share Posted August 17, 2006 Does anyone know whether this DTM text data can be imported in some other way. Via a vectorscript or worksheet etc. Quote Link to comment
dspearman Posted August 17, 2006 Share Posted August 17, 2006 3.2 mb of text!! How many data points do you have? One option would be to open it in excel and look at the data there to make sure it's clean. If you are on a mac you could also use bbedit. Quote Link to comment
jbrhwy Posted August 18, 2006 Share Posted August 18, 2006 Just checked a text files of 3700 points of survey data (point number, northing, easting, elevation & point description) & the text file size is 160 KB, but the same file in excel was 960 KB. I have sucessfully imported 1000's of text files into Vectorworks, have you choosen the correct drop down menu from the "file format" menu. Quote Link to comment
Dexie Posted August 18, 2006 Author Share Posted August 18, 2006 I've opened the data in excel and exported as tab delimited text. I have got further than before since VW has accepted the text file with no error message. The are 65,500 lines of data so it is working through it I hape will keep you updated as to the result. Quote Link to comment
Dexie Posted August 18, 2006 Author Share Posted August 18, 2006 It worked. The drinks are on me. Thanks to one an all for all the useful tips and suggestions. Quote Link to comment
dsofio Posted August 23, 2006 Share Posted August 23, 2006 I've yet to try DTM data importing in V12, but I essentially gave up from related problems with V9 I'm inferring from these posts that there (still?) isn't some less clumsy way to import survey data than via text files, created by first exporting from a spreadsheet (repeating this joyless process ad nauseum, as errors in format or data are discovered)? After this many new releases? Hopefully I am speaking too soon, and there IS some accommodation... Quote Link to comment
islandmon Posted August 24, 2006 Share Posted August 24, 2006 dsofio, XYZ Data is simple but very sensitive to corruption. Spreadsheet & text files are really ideal for editing and adding info. Spreadsheets also provide the benefit of adding Record items like point numbers & descriptions. Importing raw data TXT or VSS are proven to be easy and reliable methods. Quote Link to comment
