carch Posted August 13, 2006 Share Posted August 13, 2006 When placing dimensions on my drawing everything will show up expect the text. HELP VW12.01 Windows XP Thanks Chris Quote Link to comment
CipesDesign Posted August 13, 2006 Share Posted August 13, 2006 Chris, a couple things to check. What is the default setting for TEXT (in general)? Is it really tiny? What DIMENSION STANDARD is being used (you control this in the document settings). Is it possible that the foreground color of the text and the background color of the placement area are the same? Quote Link to comment
islandmon Posted August 14, 2006 Share Posted August 14, 2006 Peter, your response reminds me of this story: A woman called HP Support for help with adjusting her color printer because it would not print in Yellow... CMK were fine ... but not Y. After many frustrating Q&A exchanges , both HP Tech & the woman agreed that the printer was flawed and needed to be returned for service. The woman then asked innocently, "should i remove the yellow paper before sending my printer to you ?" Quote Link to comment
