Batch Print Sheet layers, page setup
CRSA_890
I might be overlooking something, but I will try.
Our office often changes the page setup (page size) so we can print scaled reduced drawings, for check sets, or owners, whatever. In VW12, I believe that you have to go into each Sheet Layer and do a page setup as it appears the page setup (page size) does not follow through to all Sheet Layers. We used to use, and still do for some projects, saved sheets and print directly from the design layers, (VW10), and a page setup would flow through, so we could easily do a 20 page batch print or Print Sheets is what VW10 called it.
So is there a way to patch print, from VW12, the sheet layers, at lets say reduced to to on a tabloid sheet without having to go into every design sheet and edit the page setup?
Am I missing something?
Thanks for your help.
Kevin
VW 12.0.1,
Mac OS 10.4.5
2 answers to this question
