Editting Windows and Generating Schedule
When you select the window, does the top of the Object Info Palette say "Symbol", "Window", or "Window in Wall"
Are you using the window tool in VW 12 to place the windows?
Hi Katie,
Since I haven't heard back from you, (I was not sure if you received the other replies) so am rewriting what I wrote in the other replies. What I get when I select the windows is"Custom Object in Wall" at the top of the Object Info Palatte. I used the window tool in the Tool Sets from the Building Shell set
The fact that it says custom object in wall, leads me to believe someone has been changed about the window tool itself.
Are you sure you are using the window tool and not Window Simple Tool or something like that?
What happens in a new document?
If you want, you can send a copy of the file along with all the details to tech@nemetschek.net and someone can take a look at it. (I'm on vacation until Tuesday, starting tomorrow)
