PDF scale issues
sinjian
Hello
Has anyone had an issue with PDF's changing scale when printed on a plotter?
The theatre I am working for has an architectural firm which donates plotter time. When I open the saved files in Acrobat, the scale seems fine, however the company I send them to claim that the scale has changed?....
Is this a common problem? A PC/Mac issue? Is there a way I can test this on my home printer?
Thanks in advance!
6 answers to this question
I would find out what PDF viewer they are using to print. It sounds like, if using Adobe Reader or the full Acrobat, that they've turned on a setting to Fit to Page in the print settings.
As I recall, there was a 3% PDF scaling error bug in the first couple version of the HP/GL Plotter Drivers ( and derivatives ) which used emulators not Postscript. But this was fixed ...
perhaps you will need to update the drivers if Katie's suggestion doesn't fix this common problem.
Thanks for your suggestions
I'll have to check with the printer.. I believe that they printed from Acrobat and not just reader... Though I never thought to ask that -I will also find out what driver they are using (Thanks for that suggestion as well, islandmon).
The other suggestion the Printer had was to export a .DWG file to them, however, that just seems to give all the 3D information (which then prints out), even though I've saved a file with hidden lines rendered...
Is this also common?
Thanks again
Hi there
Problem resolved!
It was the Reader/vs full Acrobat issue with a little summer-office-help thrown in on the side to add to confusion.
I'm still interested in whether or not you can export a .dwg file with hidden line rendering that doesn't come up in Auto
Thanks all for your help!
oooops, sorry, pressed enter before I finished the line...
I'm interested to know if you can export a .dwg file with hidden line rendering that doesn't come up in AutoCad with all the arc lines in a curve also printed
out. That would solve a lot of problems....
Thanks again for your help!
"It was the Reader/vs full Acrobat issue with a little summer-office-help thrown in on the side to add to confusion."
when i send my pdf to a professional printer i get scalable drawings. when they reduce them to 12"x18" i get exactly 50% reduction.
when i have a friend do it for me on the cheap, i get a disaster.
there is no issue.
you get what you pay for.
