td4stage Posted September 6, 2004 Share Posted September 6, 2004 I am trying to insert twofers into my plot. I click on the ganging tool, then I select the first unit, then the second, then click to select the location of the twofer. When I do this, nothing shows up and "plugin object" appears in the OI pallette. If I try this in a fresh drawing, I do the same thing and this time the twofer appears and "twofer object" appears in the OI pallette. Any suggestions! TIA Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 7, 2004 Vectorworks, Inc Employee Share Posted September 7, 2004 Check to see if you have an object or record named "Two-Fer Object". Try copying and pasting a two-fer object from another document just to see if the oibject works in the problem document. Check your layer and class snap options and make sure that you are clicking on instruments. Quote Link to comment
