Francois Levy Posted July 25, 2006 Share Posted July 25, 2006 A surveyor has provided me with an incomplete file (and of course I'm in a rush) with 914 points identified. They've imported as groups with a text object adjacent. I'd like to automate placing a 3D locus with the correct Z coordinate (given in the adjacent text). Obviosuly what I'm after is data for a DTM. Any suggestions? Manually placing 914 3D loci and assigning their Z's would be tedious. Quote Link to comment
islandmon Posted July 25, 2006 Share Posted July 25, 2006 Whenever faced with this situation my first approach is to export the file as text and then try to >find&replace in order to create a simple vss file . Or I use excel to do the same thing. Download for an example of the process: http://www.fractalnet.org/CAD/VSS_SRVY_DATUM.zip Quote Link to comment
Francois Levy Posted July 25, 2006 Author Share Posted July 25, 2006 Thanks! That's very helpful. Here's what I ended up doing--a bit more simple-minded I admit, but I couldn't have done it without seeing your examples first: --I copied all my text objects and pasted them into a clean file --Exported as a VectorScript file --In a text editor, I did a series of find/replace, replacing first TextOrigin with Locus3D then (at the end of the x,y for the text object) replacing ); BeginText; ' with , finally, I replaced '' (at the end of the line with the text object's value) with ) This had the effect of changing each text object with an x,y and value into a 3D locus with an x,y, and z, using the text object's value for the z. --I then saved the text file as MyFile.vss, then imported into VectorWorks as a VectorScript. Seems to have worked like a charm. Thanks again!! Quote Link to comment
