Ethan Posted August 20, 2004 Share Posted August 20, 2004 I have been having an issue with Spotlight losing my accessories. I will be working on a drawing for a while, and then I will look and find that none of my sidearms or irises are there anymore. All classes and layers are turned on and Export Insturment Data does not show any accessories. They are getting deleted somehow. This has happened twice this week and it is very time consuming to have to re-add all of my accessories from earlier documents. I have been importing back and forth from lightwright a bit, but that shouldn't remove accessories from my plot, should it? Ethan VW 11.0.1 MacOS 10.3.4 Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 20, 2004 Vectorworks, Inc Employee Share Posted August 20, 2004 Spotlight and LightWright are both handeling accessories now. You can add them in either place and the other software should pick them up. Make sure that on export you have the LW4 Box checked and that you map accessory the fields correctly. Your Device type should be Static Accessory (New for 11 and LW4) or LW will think they are powered accessories and treat them as devices not accessories and not associate them with an instrument. (If you are using an old libary they are probably still marked as accessories) Check to see that the accessories are listed the LW and that they get imported back into VW. Quote Link to comment
Ethan Posted December 19, 2004 Author Share Posted December 19, 2004 I know I posted this a very long time ago, but Spotlight is STILL losing my accessories every time I import info from Lightwright. This time my accessories are CXI color scrollers with channel data, not static accessories. I have them designated as "Accessory" in Object Info. I want them to have the same Position and Unit# as their linked instrument, and I want them show up in their OWN row in Lightwright. First of all, WHY is Spotlight DELETING units without my sayso, and how can I get accessories to work right EVERY time I import and export?? Ethan Mac OS 10.3.5 / Vectorworks Spotlight 11.0.1 Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 20, 2004 Vectorworks, Inc Employee Share Posted December 20, 2004 Ethan, Are you using Lightwright 3 or 4? Do the accessories show in LW? What is the device type in LW? Quote Link to comment
Ethan Posted December 21, 2004 Author Share Posted December 21, 2004 - Lightwright 4 - The accessories are all there in Lightwright. - The accessories are listed as "Lights" under "Instrument Type" in Lightwright. Is that the problem? How do I fix it? [ 12-20-2004, 12:44 PM: Message edited by: Ethan ] Quote Link to comment
Ethan Posted December 22, 2004 Author Share Posted December 22, 2004 Talked to Nemetschek, and fixed the problem. My import instrument data plugin file was outdated or corrupted. Nemetschek sent me the new file and that took care of the problem. Quote Link to comment
Ohran Posted September 2, 2005 Share Posted September 2, 2005 I am currently having the same problem. Can someone send me this new file? P4 2.4ghz 1 gig ram 11.5.1 lw4.1.1 Quote Link to comment
