mark_at_custom Posted July 20, 2006 Share Posted July 20, 2006 Hello all, Long time VW user, however, I'm a newb at spotlight. Is it possible to create and project a multicolored gobo image, of an imported jpg, with a transparent background, from an inserted instrument onto a surface? Or is it just easier to map a photoshopped transparent texture onto the surface? I like the idea of the gobo projection because it can be "projected" onto multiple surfaces at once. Thanks! Any help will be appreciated! Mark Quote Link to comment
mark_at_custom Posted July 20, 2006 Author Share Posted July 20, 2006 Well okay, It dawned on me, if the background for the graphic is black, then, Viola! It goes away; allowing for a multi- colored graphic with a "transparent" background. Also, was able to manipulate the spacing of the image in the projection area with the "image size" stretchy thingy under the edit resource window. So, it's all good. Thanks. Quote Link to comment
