Mar,
If you are using negative layer elevations you will recieve the error. It's a bug. Change the design layers to stack all in the positive direction with 0.0 at your lowest level or...put the stair height in manually in the PIO. In order to find the bad stair you will need to exit VW and come back to the job to make the edits to the stairs. Once the error shows up the only way to get the PIO back is to restart VW.
Pete Anthony
