APE Design Ctr Posted July 11, 2006 Share Posted July 11, 2006 Has anyone some extensive experience with this plugin, specifically for VW12 to C4D 9.6? I have been using VW11.5 and C4D 9.1. I have noticed that some of the geometry gets translated incorrectly, and I am hoping there are some improvements. Thanks! Quote Link to comment
G_Hannigan Posted July 11, 2006 Share Posted July 11, 2006 Eddie, I'm using VW12 & C4D 9.6 with VW Exchange Plugin R2. Seems to be working OK. What type of geometry is a problem? Is it always the same type of geometry? George Quote Link to comment
APE Design Ctr Posted July 11, 2006 Author Share Posted July 11, 2006 sometimes it is extrudes along path. Tube geometry. Say I have a long tube that I extruded along a path. Sometimes the translation shows it as almost like taking a vertical cross section of the tube, so I have a thin rectangle the length of the tube. Quote Link to comment
G_Hannigan Posted July 11, 2006 Share Posted July 11, 2006 Not sure what's causing the problem. I did some tests but couldn't get that to happen. You say that it only happens sometimes, is there a common feature in those objects? George Quote Link to comment
APE Design Ctr Posted July 12, 2006 Author Share Posted July 12, 2006 I just did a test now. I did an extrude along path, with a circle, and just a normal circle extrude. Then I did a NURBS path, and did a circle extrude along NURBS path. The normal circle extrude is fine. The extrude along path converts to a square profile on one part, but along the elbow it is fine. The extrude along NURBS path doesnt even show up except for the circle profile. I dont have an easy way to add images to this post, but I can email you if you are very interested. Thanks Eddie Quote Link to comment
G_Hannigan Posted July 12, 2006 Share Posted July 12, 2006 I just did the following test: 1. Circle w/ polyline as path(used corner pt, cubic & bezier). 2. Circle w/ Nurbs curve as path. 3. Nurbs circle w/ Nurbs curve as path. 4. Exported (Class option). 5. Opened in C4D 9.6 I didn't get any of the flaws you describe. They look the same as in VW. Perhaps VW 12 & C4D 9.6 are OK in this instance. Send me a PM of an example if you like. George Quote Link to comment
APE Design Ctr Posted July 12, 2006 Author Share Posted July 12, 2006 George, can I have your em. Cant find it on your website. Quote Link to comment
Ray Libby Posted July 12, 2006 Share Posted July 12, 2006 PM= Private Message. Click on George Hannigan on the left side of his post, then click on the Private Message button. Quote Link to comment
APE Design Ctr Posted July 12, 2006 Author Share Posted July 12, 2006 Sorry... I should have known!. Quote Link to comment
David Ormsby Posted July 15, 2006 Share Posted July 15, 2006 Any luck on this? I tried George's tests and got good results. Is it possible you have the 3D conversion res set to low? Quote Link to comment
