Fredrik
No adjustment for grid length in grid bubble diagr
No matter what I do I can't adjust the length on the grid line in the grid bubble diagram. Making a new with another length do no difference. It is fixt to 2,5 m. Is this a bug?
3 answers to this question
Now, I could make a grid buobble diagram with another lengt in a new empty file. I copied the short one into the new file and tried to change, but no. Another grid seemed to be locked too.
Try resetting the user origin and see if that fixes the problem.
Re-setting I did not find. I changed the origo without any change on the matter.
What helped was first make a set of lines on the horisontal bubble set and copy it to a new file. I could then make a bubble line and set grid length. That didn't work for the wertical one, byt by copying the one I had in the file and rotate it and change it I made the vertical good too. The actual case includeed several new files and tryes.
Strange was when copying a grid bubble I got a text number, when pasting it in a new document. Second try did give me the grid bubble.
