Model Set up Won't Allow 8'-1" Hieght
VW is understanding the dash as a minus sign and doing the calculation correctly. You can use a space to separate the feet units from the inches unit. You will need to use a ' to identify the feet but if the units are set to feet and inches or inches, you will not need the inch marker.
