Framing Member
You've entered values beyond the Object's "database" . . . it doesn't know how to convert what you've entered into a nominal size. I'm presuming metric has an equivalent to our Imperial 2"x4" (nom) which translates to 1.5"x3.5" (net). You can add to the database, but it's fairly arcane. If this is a size you use frequently and would like to modify things, please repost.
Good luck,
