Assembly Posted June 23, 2006 Share Posted June 23, 2006 I know there is a function to hide parameters in the Object Info, I used it in an old plug-in, but can't remember what it is. And cant find it in the Reference Guide. Can some one please post it. Thanks Quote Link to comment
ccroft Posted June 24, 2006 Share Posted June 24, 2006 Not a function really. Just name the parameter with 2 underscores in front: "__ParamName" Quote Link to comment
Assembly Posted June 24, 2006 Author Share Posted June 24, 2006 Thanks for your reply Ccroft.... I guess I need to explain myself a little more. Down under in New Zealand there is an Index for Construction information. Works like this. 1 General 2 Site 3 Structure 4 Enclosure ...etc. Information can then be classified in more detail. ie under structure. 31 Concrete 32 Steel 33 Timber 34.... The system continues in more detail.... 311 Concrete Floor Systems 312 Precast concrete. So say you are specifying Precast concrete walls. The section of the spec the information is found is 312 Precast concrete. The PIO I am creating allows for a Keynote text, then requires the user to appened where in the spec that information is found. How to do that... The PIO has a series of popup menus to navigate down the index. The idea is you start with a top level pop up. You select '3 Stucture'. In the PIO this controls what the next pop up is that is displayed. You can then select 31 Concrete, which reveals the next level popup and so on. What is missing from the script is: If '(pSpecsectionpop='2 Site') Then (*THIS IS THE FUNCTION I NEED* Show popup2 & Hide the other popups. I know this function exists, in V11.5 the Door tool has a number of boolean parameters in the object info. Click on one and a the rest of the parameters become visible. Make it false and they disappear. This is the function I'm looking for. Cheers Quote Link to comment
Assembly Posted June 25, 2006 Author Share Posted June 25, 2006 Found it!. SetParameterVisibility Quote Link to comment
