Use the dimension tool to dimension an object on a drawing. The dimension will be selected. The object info palette allows you to change many attributes of the dimension, but it does not allow you to change the size of the text. To do that you have to go to the menu bar under text. I think you should be able to alter the text size (and font?) from the object info palette.
