sn9
extended properties
the following text occurs when i try to start up vectorworks after installation
'vectorworks failed to startup because the ExtendedProperties plug-in failed or is missing from the instalation'
how can this be rectified?
4 answers to this question
Reinstall the application.
Remove the current folder and reinstall from the installation disks.
I have tried to reintall the application several times and the same thing happens everytime.
We were recently sent a replacement disk as the one we had was faulty. Can it have something to do with the DVD-Version 12.0.1?
No, you shouldn't have that problem with the DVDs.
Are you getting this message with the replacement disk?
the message is from the replacement disk
should i be contacting the supplier to report it as faulty? or is there a plug-in replacement that can be obtained?
