Matt D Posted June 18, 2006 Share Posted June 18, 2006 I am trying to create simple park railings using the handrail tool. However, I cannot remove the top rail to allow verticals to rise above the horizontal rails as in traditional victorian railings. I need the plan view to show the 10mm x 10mm round veritcals at 100mm spacing. Also, the handrail does not change when I select different styles. Does anybody know what I can do?? Many thanks to anybody who can help. Matt Quote Link to comment
David Ormsby Posted June 18, 2006 Share Posted June 18, 2006 There is a plug in available that may create railings as you describe - check the VectorDepot site - http://www.vectordepot.com/PlugIns1.shtml Quote Link to comment
islandmon Posted June 19, 2006 Share Posted June 19, 2006 Image Prop railings provide specific look&feel details with low overhead. Quote Link to comment
Kevin Posted June 19, 2006 Share Posted June 19, 2006 There is a plug in available that may create railings as you describe - check the VectorDepot site - http://www.vectordepot.com/PlugIns1.shtml This tool shows promise. However, it lacks needed controls. Quote Link to comment
