goochpurdue Posted June 8, 2006 Share Posted June 8, 2006 I hope I am missing something here. I am a fairly new user to vectorworks having most recently used WYSIWYG. I have a truss that I have rotated 30 degrees in the Z axis using the hanging rotation feature of the truss tool. It is also rotated 45 degrees or so off of the x axix. So basically we have a diagonal running USC to DSR and points up in the air on the US side and towards the ground on the DS side. I can't find a good way to attach lights in 3d. Everything I have tried winds up with lights not being placed anywhere close to the truss. I have even drawn a 3d poly where the 6 bars would go in the truss and converted it to a lighting position. I am drawing this model to export to ESP Vision, so it needs to be accurate in 3d space. Please tell me I am missing something so obvious because I am about to pull my hair out. Cheers! Geoff Gooch ggooch@purdue.edu Quote Link to comment
islandmon Posted June 9, 2006 Share Posted June 9, 2006 Usually, when doing structural attachments it's easier to do everything while on the base XYZ Plane . Then once everything is set-up properly ... rotate the entire structure as a single unit using the Tool>'Rotate 3D' Procedures. First try grouping them and then rotating ...but, for various reasons sometimes the groups will not rotate in 3D space. Quote Link to comment
goochpurdue Posted June 9, 2006 Author Share Posted June 9, 2006 I think the thing that is keeping me from rotating the most are hybrid objects. Is there an easy way to delete just the 2d portion of symbols from Spotlight while leaving the 3d version in place? Geoff Gooch ggooch@purdue.edu Quote Link to comment
islandmon Posted June 9, 2006 Share Posted June 9, 2006 First, duplicate&rename the symbol(s) then > symbol>edit>2d>delete. Then Replace existing hybrids with the new 3d only versions. Quote Link to comment
David Ormsby Posted June 10, 2006 Share Posted June 10, 2006 If you've updated Vision recenty, they have included a symbol library optimized for Vision use - no 2D geometry. Should be in your Vision folder. Quote Link to comment
tommy_hague Posted June 20, 2006 Share Posted June 20, 2006 Hey, I am having the same maddening problem, too. 'bout ready to throw my new VW 12 out the window. WHY can I not rotate the 3d part of my symbol? I still need the 2d to show up on the plot but I need to have the trusses angled properly in the section. Not to mention wanting to draw a vertical truss for another hanging position. Quote Link to comment
