Text Wrap Default
Hodgie
This has been a very long-standing complaint of mine (and of others). The only way that I know will work is to: a) use wider number stamp objects and, b) use smaller text. Also, it is very likely that different fonts will produce different results as some have characters closer (or farther) from each other.
If it becomes necessary to fix vertically stacked text in number stamps, you can enter the object (which is a simple group), edit the text block (by stretching it horizontally) and then exit the group.
Ultimately, I don't experience many problems with this anymore because I have found the sizes / fonts that seem to work for me.
Peter Cipes
G5 1.8x2 / OS 10.3.3 / VW's 10.5.1
