TBrown 0 Posted June 5, 2006 Is it possible to create a viewport from a design layer that shows portions of the drawing in sketch mode and portions shown in regular line work? When I try to do this I can only set a global rendering setting and the entire viewport is shown sketched. The only thing I have tried that works is to over lay two viewports showing two different settings. Quote Share this post Link to post
CipesDesign 148 Posted June 5, 2006 I think that the overlaying of two (or more) VP's is necessary to do this. Quote Share this post Link to post
Spunkmeyer 0 Posted June 5, 2006 The only way I know to do it is to specifically set the sketch settings in the design layers (via the render tab) and set the items you don't want to have sketched to be 'no sketch'. Then, set the viewport to sketch and you should see only the portions not set to 'no sketch' as non-sketched lines. Hope this helps... Quote Share this post Link to post
Jonathan Pickup 273 Posted June 5, 2006 i would overlay 2 or more viewports Quote Share this post Link to post
