megj Posted June 2, 2006 Share Posted June 2, 2006 When I go to insert a door, it does not insert like it normally does. Usually the door will pop into place, and have an opening. Now, when I go to insert the door, there is the door swing, a solid block (where the opening should be) and there are 2 spaces on either side of the block that have lines in them. What is this? How do I get my normal door back? Quote Link to comment
CipesDesign Posted June 2, 2006 Share Posted June 2, 2006 Check to make sure the "wall inserion mode" is active (in the mode bar, upper left of the drawing window). Quote Link to comment
megj Posted June 2, 2006 Author Share Posted June 2, 2006 wall insersion mode is active. it is still showing up wierd. it looks like the door opening is blocked off and that there are openings on the left and right side of the door. Quote Link to comment
Christiaan Posted June 2, 2006 Share Posted June 2, 2006 There're not two walls on top of each other is there? Quote Link to comment
megj Posted June 2, 2006 Author Share Posted June 2, 2006 No, it is only a single wall. Quote Link to comment
Guest Posted June 2, 2006 Share Posted June 2, 2006 Set the class called Ceiling-Main to be invisible. Quote Link to comment
megj Posted June 2, 2006 Author Share Posted June 2, 2006 that doesn't help. katie- is there any way i can show you what exactly is happening? I'm new to the forum... Quote Link to comment
MKingsley Posted June 2, 2006 Share Posted June 2, 2006 Maybe you have the sidelites on in the PIO settings and the overall width not big enough to accomodate them so it's looking strange. Quote Link to comment
Guest Posted June 2, 2006 Share Posted June 2, 2006 Megj- Sure - you can either send the file or a screen shot to me at tech@nemetschek.net Subject - attn: katie Quote Link to comment
Guest Posted June 5, 2006 Share Posted June 5, 2006 Meg, The ceiling-main class is visible in the file you sent. Be sure to set this class to be invisible to have the door display properly. Quote Link to comment
