dunsterville Posted May 25, 2006 Share Posted May 25, 2006 (edited) How do I access the Plug-in files, VW tells me that I can't open or import them, and I can't see them displayed in the workspace. They look like they could be really useful to me. So, for instance if I do an 'Open' all the files in the plug-ins folder are grayed-out, the same goes if I try an 'Import', and I'll get an error message if simply double-click these files. Another issue I have is the browser-based VW Help ? the 'links' just hang (at least, they do in Safari). Edited May 25, 2006 by dunsterville Quote Link to comment
islandmon Posted May 25, 2006 Share Posted May 25, 2006 Those little snipets of code are very specific procedures that do wonderful & important things using the VW Libraries. They are accessible via Workspace Editor> Tools ( drag them onto palettes or create new palettes ). They are also useable via the Plugin Editor. And with a little practise you can even write your own scripts ( there are examples at www.vectordepot.com ). As I recall with Safari , due to security & Java issues check your permissions then restart. There's no actual problem endemic to Safari & VW Help. It appers to be an OS issue of protections. Quote Link to comment
Guest Posted May 25, 2006 Share Posted May 25, 2006 The plugins in the plugins folder inside the VW folder are all tools and menu items that VectorWorks already has. For example, the door.vso item is the door tool. Most of these items already exist in one or the other workspaces, but you can use the workspace editor to add the ones that may not currently exist in your workspace. Quote Link to comment
Ian M. Posted July 26, 2022 Share Posted July 26, 2022 If a Vectorworks user has created a new tool and posted it to the Vectorworks forum, how would I access that tool? I have searched for instructions, but I must be using the wrong search terms. Thanks in advance for any help. Quote Link to comment
rDesign Posted July 27, 2022 Share Posted July 27, 2022 (edited) The three types of plug-ins are menu commands (.vsm), tools (.vst), and objects (.vso). 1) Best practice is to close Vectorworks and copy the plugin items (.vsm, .vst, .vsm) to your User Plugins folder: Windows: C:\Users\<Username>\AppData\Roaming\Nemetschek\Vectorworks\<version>\Plug-Ins Mac: /Users/<Username>/Library/Application Support/Vectorworks/<version>/Plug-Ins 2) Open Vectorworks and add the command / tool / object to your current Workspace using the Workspace Editor. Edited July 27, 2022 by rDesign 4 Quote Link to comment
