Squiidly Posted May 22, 2006 Share Posted May 22, 2006 Updates from VW 11 or otherwise came with no manual, with the idea that one would use the "Help" window when baffle fluttered yer noggin. The help window, for me, only works perhaps 20% of the time I click on it. For the most part, it just sits there with full menu and the new 12 logo, not responding to anything. Anyone else? Quote Link to comment
David Ormsby Posted May 22, 2006 Share Posted May 22, 2006 Are you on a Windows machine? - recent updates to IE require you click the little yellow bar at the top of the window to activate the active content in the window. Quote Link to comment
Guest Posted May 22, 2006 Share Posted May 22, 2006 Please read the following Knowledge Base article: http://kbase.nemetschek.net/index.php?ToDo=view&questId=79&catId=23 Quote Link to comment
Squiidly Posted May 22, 2006 Author Share Posted May 22, 2006 I'm on a Mac. It sounds like I need to use a different browser than Safari. Thank you. Quote Link to comment
Bruce Kieffer Posted May 31, 2006 Share Posted May 31, 2006 It may be a JavaScript bug. I've had better luck since the last OS update. Make sure you have the latest update installed. Use Software Update under the Apple menu to check. I've also found that opening the file directly from finder works to load the JavaScript (locate it in your VW app folder inside the help folder, it's called index.htm). Quote Link to comment
roll Posted May 31, 2006 Share Posted May 31, 2006 Thanks Bruce - opening directly from Finder works much better, if a still bit slow. I have dragged the index file to Dock for quick launch. Quote Link to comment
