iDigDesign
Circuiting Tool Won't Work
How do you get the circuiting tool to work in VW12 Architect. I keep gettng the error message "There are no panels in the document". I have tried adding a "Panel", using the resource tool and giving it a unique name as suggested in the EXTREMLY SKIMPY help section. There ought to be a panel right in the MEP tool box I could add.
Use the panels from
...\Libraries\Objects-Imperial\16_Electrical_Panels.mcd
The name of the panel is specified in the Panel Record atatched to the symbol. In the data pane, select the panel Record then select the name field and change the name in the lower pane of the OIP. It defaults to LPB-0.
Edited by klinzey
