jhodges Posted May 8, 2006 Share Posted May 8, 2006 I've recently moved companies and from AutoCAD 2004 to Vectorworks 12. I've started setting up some CAD standards at the new place and have a template drawing with a whole bunch of classes in. In AutoCAD, it's really easy to open a drawing from within its Design Center (much like the Vectorworks Resource Browser) and to copy classes, dim styles, text styles and linetypes between drawings. Is there any way to do this with Vectorworks 12? I can only see how to copy symbols and hatches with the resource browser. I guess I could start with the template file each time, but most of my work is adding lighting layouts ontop of architectural drawings that I receive as DWGs. Copying classes into the drawing works much better for this. Any ideas? Jon Quote Link to comment
islandmon Posted May 8, 2006 Share Posted May 8, 2006 You can also utilize the Work Group Reference protocols. Quote Link to comment
David Ormsby Posted May 9, 2006 Share Posted May 9, 2006 Several years back, I ran into this challenge. I ended up making a symbol, which I names "classes". It's basically a stack of duplicated rectangles each with it's own class (from my custom template). That way, if I am starting from someone else's file, I just drop that symbol in, and viola! - all my classes are now there. Quote Link to comment
jhodges Posted May 9, 2006 Author Share Posted May 9, 2006 Thanks guys, as I suspected. It sounds like something I've got to use a workaround for. I'm pretty surprised that it's not part of Vectorworks, seeing as class structure (layers) is absolutely fundamental to CAD standards within a company. Maybe I'll add it to the wishlist... I'm not sure what the work group reference protocols are, they don't seem to show up in my documentation. I'll keep looking though. My colleague was suggesting a similar method to your symbol method Dave, I was just hoping there was a simpler method. I really can't understand why you can't get classes and layers out of the Resource Browser but still. Jon Quote Link to comment
Christiaan Posted May 9, 2006 Share Posted May 9, 2006 It's possibly a stretch to call the use of Workgroup Referencing with a template a work around, but not much of a stretch. Quote Link to comment
jhodges Posted May 17, 2006 Author Share Posted May 17, 2006 Hi Folks, Right, so I'm back on case here. I've used Workgroup Referencing to copy in the template into my drawing but only the Layers show up. Is it possible to use this method to insert Classes? Any ideas Islandmon? Thanks for your help, Jon Quote Link to comment
