Location of RW texture images?
Jeffe'
The actual image as an image file is not supplied.
The easiest thing to do is create a block in VW and assign the texture to it. Then, using the export image functionality, export an image of just the rendered block.
You then have an image file that can be manipulated in a photo-editing software application.
