IanH Posted May 2, 2006 Share Posted May 2, 2006 Apologies if half this post is somewhere else, I hit the wrong button and lost my previous post without finishing it. I am having problems with worksheets giving me the results that I expect. This is under VW 11.5 on WinXP. At a very simplistic level, I have created a record to allow me to cost materials. The record contains: ID - Text QTY - Number PRICE - Number Using the following simple example, hopefully someone can tell me if what I want to do is possible. I have 3 individual components, each made up of half a plank of wood. The cost of one plank of wood is 10 and I can only buy it in whole planks. So I will be using 1 1/2 planks of wood, will need to buy 2 planks and the total cost will be 20. In VW, I have 3 identical instances of the record. ID - BEAM - the part identifier REQ QTY - 0.5 - half a unit UNIT PRICE - 10 - total unit price 10 What I am looking for is a worksheet that contains the ID a total quantity and a total price all grouped by the same ID. So it should read. ID REQ QTY UNIT PRICE ORDER QTY ORDER PRICE BEAM 1.5 10 2 20 Order Qty and Order Price are derived as follows. ORDER QTY = REQ QTY rounded up (ie ROUND(0.5+REQ QTY)) ORDER PRICE = ORDER QTY * UNIT PRICE Unfortunately, It would appear that I have no control over whether I am using an individual instance of a field or I am using the sum of all the fields as grouped. So if I group by ID I get: ID REQ QTY UNIT PRICE ORDER QTY ORDER PRICE BEAM 1.5 30 3 140 / 60 ORDER PRICE is either 140 or 60 depending on if I calculate it from ORDER QTY or from the "EXAMPLE.UNIT_PRICE" record field. If I leave ungrouped I get 3 instances: ID REQ QTY UNIT PRICE ORDER QTY ORDER PRICE 3 1.5 30 3 30 BEAM 0.5 10 1 10 BEAM 0.5 10 1 10 BEAM 0.5 10 1 10 Unfortunately neither examples are correct. What I need to do is tell VW is: Derive ORDER QTY from the sum of the REQ QTY field Derive ORDER PRICE from a single record instance of UNIT PRICE * ORDER PRICE But I cannot see how to do this (or even if it is possible). I don't want to change the meaning of price to mean the price of the instance as I don't want to have to keep calculating fractional values everytime that I use a different QTY. Hopefully this is clear - it may need loadding in a fixed pitch font to get the columns to align. Can anyone assist even if it is to say that this is impossible. Thanks Quote Link to comment
islandmon Posted May 2, 2006 Share Posted May 2, 2006 I used a Class 'Beam', (formulas are indicated under the cells) : Quote Link to comment
