JHEarcht Posted April 28, 2006 Share Posted April 28, 2006 VectorWorks 12.0 on Win XP was working fine this morning. I came back after a jobsite visit and started up. I noticed the Tools palette was empty and the Resource Browser was on default. Assuming the Preferences file in the Registry was corrupted, I replaced it with a saved backup. this didn't fix the problem, so I tried to edit the WorkSpace. As I opened the WS Editor, this dialog popped up: "the workspace could not be read. Either it is invalid, or there is not enough memory." Looks like I will have to re-create my workspace. but what could corrupt the QuickTime file? Do I need to save a backup of my WorkSpace.qtr file in addition to the Registry Preferences? Quote Link to comment
Guest Posted April 28, 2006 Share Posted April 28, 2006 Did you restart the computer before you did all the other steps? Quote Link to comment
Guest Posted April 29, 2006 Share Posted April 29, 2006 Can you zip the "bad" workspace and send the file to me? I can examine the workspace to see what might have caused the problem. Is there anything that you can think of that changed about your computer from the time it was working to the time it was not working? Quote Link to comment
JHEarcht Posted May 1, 2006 Author Share Posted May 1, 2006 Katie I have already set-up a new workspace, and replaced the preferences registry with a backup. As far as I know, nothing had changed. I left VW running and went to lunch. when I came back and started drawing, I noticed that some of the palettes were empty. I'll send you a copy of the old corrupted workspace file. Just in case this happens again, I have backed-up both the registry and the WS file for future reference. Quote Link to comment
JHEarcht Posted May 3, 2006 Author Share Posted May 3, 2006 VW12.0 on Windows XP My Workspace has been corrupted again. I think I left it running, and when I came back after a couple of hours it was turned off (but I can't remember for sure). When I started up again it went to the default WS. I fixed it by substituting the backup .qtr file I made a couple of days ago. Am I the only one with workspace woes? Any idea what could cause repeated corruptions? Could a sudden shut-down do it? Quote Link to comment
P Retondo Posted May 4, 2006 Share Posted May 4, 2006 (edited) I had a problem with my workspace, forwarded to NNA as a bug report. No word yet on what the problem was. I've now rebuilt it, and the only difference is that I renamed a script-based tool that had a special character in front of its name - just removed the special character. No problems so far, but it's too soon to tell. I'm wondering why NNA can't debug these corrupt workspaces to isolate the problem. In my case, VW failed to boot and gave an error message, until I removed my .qtr file. Edited May 4, 2006 by P Retondo Quote Link to comment
Guest Posted May 4, 2006 Share Posted May 4, 2006 JHEarcht - Are you have sudden shutdowns of your computer? Quote Link to comment
Guest Posted May 4, 2006 Share Posted May 4, 2006 P Retondo - We examined your workspace file, but it was corrupted in such a way as it could not be read. But about this script-based tool that had the special character in front of it - where did you obtain this script, and what was the special character you deleted? Any information you provide can help us investigate this. Thanks! Jeff Geraci Software Developer Nemetschek North America Quote Link to comment
P Retondo Posted May 5, 2006 Share Posted May 5, 2006 (edited) Jeff, 1) did you verify that including my corrupted workspace file in the workspace folder causes VW to freeze while booting and 2) does it make any sense to step through the code to see if you can isolate the problem? Or was the file basically a train wreck? The script was obtained from VectorDepot. It's a plugin called "Toggle lineweight zooming", and you can download it to take a look at it. I've been using it since version 8.0. The special character was a dot-type bullet in front of the name that appears in the drop-down menu (it appears as a verical line in the VectorScript Plug-in editor window, if I recall correctly). Here's the script itself: Procedure zoom; begin SetPref(9,not GetPref(9)); end; run(zoom); I'd suggest that if VW encounters a corrupted .qtr file when loading, it should give a warning and continue the loading process by skipping the corrupted file. Thanks for your good work! Edited May 5, 2006 by P Retondo Quote Link to comment
Guest Posted May 5, 2006 Share Posted May 5, 2006 P Retondo - Yes, I verified that the workspace file caused VectorWorks to freeze at startup. Unfortunately, the workspace file was corrupted at such a fundamental level, that it could not be opened. Thanks for the info as to its origin. I will continue to investigate. Quote Link to comment
JHEarcht Posted May 5, 2006 Author Share Posted May 5, 2006 Katie No, the computer is working fine. But I was just wondering if something might be causing VW to shut-down when I am away. I'll have to be more observant in the future, so I can remember if I shut-down VW before I left. both times this happened, I returned after a couple of hours away, and found the empty or default palettes after start-up. Something seems to be targeting the WS file. I haven't added any scripts or old tools, so I can't guess what the problem is. Oh well, back to the old workspace . . . Hey, where'd my palettes go? Quote Link to comment
JHEarcht Posted July 25, 2006 Author Share Posted July 25, 2006 (edited) VectorWorks 12.0 on Windows XP My workspace was corrupted again after a brief shut-down and re-start. Since this has happened several times, I now keep a backup copy. That fixed the problem for now, but I would still like to find out what is causing the corruption. If anybody is interested, I am holding on to some of the bad .ws files. Edited July 25, 2006 by JHEarcht Quote Link to comment
JHEarcht Posted July 26, 2006 Author Share Posted July 26, 2006 Since corruption of my Workspace file has become commonplace, I can now say that the problem occurs after a shut-down and restart during the same day. For some reason, after a night's rest, the corruption doesn't happen---so far, anyway. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 26, 2006 Vectorworks, Inc Employee Share Posted July 26, 2006 JHEarcht, what (if any) third-party plugins (or custom plugins that are not part of a "standard" NNA product) are in this workspace? Quote Link to comment
JHEarcht Posted July 27, 2006 Author Share Posted July 27, 2006 Robert The most likely culprit is VP Magic Wand.vst (class & type)from Vector Plug-ins. I have only used it once since installing it about 5 months ago, and the workspace problem only started in the last month. I'll remove it and see what happens. Quote Link to comment
