RonMusselman Posted April 26, 2006 Share Posted April 26, 2006 To make a 2D section, the manual for VW12 says to select a 3D object, then under model choose Cut 2D section. I don't see any cut 2d section choices. What am I doing wrong? Quote Link to comment
Taproot Posted April 26, 2006 Share Posted April 26, 2006 You may need to verify the location of the 2D section command. Depending on the workspace you are using, it may be located in another menu. In my setup, it is located under the AEC menu. If you are unable to locate it at all, then edit your current workspace, open the All Menu (flip down toggle) and then add "Cut 2D Section" to the location of your choice. Good Luck! Quote Link to comment
RonMusselman Posted April 26, 2006 Author Share Posted April 26, 2006 OK, thanks, Matt. That solved the problem. Quote Link to comment
