Nigel @ Hallam Garden Desi
Problem producing 3D contours from imported data
Here's the process I've gone through:
1 Imported DWG file
2 Converted polyline contours to polygons
3 Entered relevant data in 2D polys to 3D contour dialogue box & click OK
4 When Set Elevation dialogue box appears - all contours disappear
5 Click Next button - one, seemingly random poly has been converted & I get the final dialogue box asking me if I'd like to delete the original 2D polygons. The net result is that only one 3D contour has been produced.
- any suggestions?
Trick ... copy a couple of those polys to a new file then export as Vectorscript. Open the export with a text editor and take a look at the {Object Creation Code} coordinates. They must be in the form 'x,y,z'. here's the correct syntax for 3D Locus creation:
NameObject('1');Locus3D(5000,5000,100);
Record(LNewObj,'SURVEY');
Field(LNewObj,'SURVEY','ELEV','100');
Field(LNewObj,'SURVEY','DESCRIPTION','nls');
FPatByClass;
FillColorByClass;
LSByClass;
PenColorByClass;
LWByClass;
MarkerByClass;
Thank you islandmon - I'm afraid my expertise doesn't run to interpreting Vectorscript, but here's what it is:
Marker(0,0.444458,15);
NameClass('contours');
LSByClass;
PenColorByClass;
LWByClass;
FillPat(0);
FillFore(48059,48059,48059);
FillBack(48059,48059,48059);
Poly(
20.367266665892018,-8.427288888402076,
18.993157893907394,-11.368289472908405,
21.280883720457247,-12.892046510710014,
22.479617020317487,-14.384297871749437,
26.382275861191726,-17.59920689605714,
29.407026314864567,-16.068684209780773,
31.006674417858402,-16.327209301469804,
31.936566036790449,-16.041471697715657
Suffice to say that the conversion from 2D polys to 3D contours is not working - I've tried it out on a number of imported files and always get the same problem.
Can anybody help?
The {Object Creation Code } for the Poly(....); lacks a Z value. Hence no 3d contours. There must be 3 strings one for each value X,Y,Z,
Neat trick , hey. Now just go and add some Z values ... and watch what happens.
FYI :
Represents Record= 'SURVEY' with Field= 'Description ' = 'nls'
Nigel,
The best thing to do is import the DWG using the 3D only settings.
By importing 2D and 3D, the default view items are what gets imported - this means everything comes in as 2D.
As long as the items are 3D in the DWG file, you shouldn't have to do much work other than line cleanup.
