version problem
TN
You can open the VectorScript Editor in Version 12, copy the text of your script, then open the VectorScript Editor in Version 11, create a new script, paste in the text that you just copied, and save the script in version 11. Of course, any procedures new to version 12 will fail in version 11.
Once updated to a newer version, a script file cannot be moved backwards to a previous version plug-ins folder, but the text of a script can always be moved backwards to a previous version script by copy and paste.
Thanks for the reply. That does work, to cut and paist. The problem is that I have a lot of parameter info that You can't cut and paist. If there is no to go backwards then I am probably better off writing all scripts in an older version if I want them to be backward compatible.
