Using VW 11.5 importing AutoCAD DXF or DWG files. I've noticed a lot of excessive lenght dimension lines when importing. If I view the PDF of the imported file the dimension lines contain arrowheads. However they import as "slashes", similar to the Arch standard. and the slashes are real long and you can't alter the lenght at all, just the size of the corresponding witness lines. If I change the dimension standard, I get giant arrowheads. Any ideas as to how I can fix this import issue?
Razzman
Thanks,
Bill Rzasa
3 answers to this question
