chstech Posted October 5, 2003 Share Posted October 5, 2003 I'm working on a Mac, Spotlight 9.5x. Plot was Exported from a Mac, Spotlight 10.5. I can not edit info in the Object Info Palette. When trying to change Position or Purpose I recieve the following error; "Object Creation Failed Due To Invalid Parameter(s). Please Use Different Parameter(s)!" The fixtures are 'Spotlight' symbols and already have color & channel info. This is only happening in 9.5. Any ideas?!? Thanks, Drew Quote Link to comment
James Milkey Posted July 14, 2004 Share Posted July 14, 2004 I'm actually having the same problem on a PC with 9.5 but it started as a 10.5 file. Exact same error and everything. Quote Link to comment
Guest Posted July 14, 2004 Share Posted July 14, 2004 What types of objects are they? IF they are doors and/or windows, you'll need to run Update to V2 objects command under the Tool>Utilities menu. Quote Link to comment
comical Posted July 26, 2004 Share Posted July 26, 2004 I am having the same exact problem. The file that I am working on was created in MiniCAD (don't know which version) and due to the fact that 9.5 doesn't open old MiniCAD files, it had to be opened in 10.X . Now whenver I attempt to change the any information pertaining to lighting fixtures in the object info bar, it gives me the same message descirbed above. I have tired deleting the "Light Info Record" and creating new layouts for the symbols but nothing seems to be working. (I am currently working on a PC, 9.5.1, the file was converted on a Mac running 10.(?) ) Anything at this point will help, otherwise I will have to copy and paste into a new file and hope that works. _Lance Quote Link to comment
