mjelacic Posted July 25, 2002 Share Posted July 25, 2002 Sometimes when I extrude a shape only the 'z' faces show as solid, The original face of the 2-D object are transparent. If I add a texture to these objects, all sides a filled. Any ideas what might cause this? Quote Link to comment
MikeB Posted July 25, 2002 Share Posted July 25, 2002 Usually this is caused by an open polygon. Check your Obj Info Palette and make sure your shape is closed. If its a polyline convert it to a polygon and check to make sure its closed. Good Luck Quote Link to comment
