Feature Requests-Installer
RickBern
Cross posted this from the 12.0.1 updated installer thread:
Paul
Thanks for the heads up
A couple of requests for the upgrade process
1
PLEASE allow me to paste the serial number into the updater's dialog box. I have 40 machines to update and this is tedious to type in over and over.
2
Along those lines-can I download the updater files once and access them locally. The web based updater is OK for a 10 user office but gets impractical at a larger firm.
3
If you have to revise a release can it have a different version number. 12.0.2 or 12.0.1a would be easier to identify than going through the install process twice to find out you have the correct version.
Thanx in advance
Rick
1 answer to this question
1. An improvement in this is in the works. [Wink]
2. You should just go ahead and pay the nominal charge and have a DVD sent to you, which is even faster than installing from the network. [smile]
3. Yes, we can do a better job of this.
Thanks for the comments.
